You can hit a rock, even inside the wood on the 1st cut.
A nail is highly likely too, if "tree service"or "home owner" wood.
Some you won't even notice but if the cutting tip is shiny, you probably hit something.
I've seen concrete in the hallow middle. (Home owner poured it full to save the tree, was in SW Pa.)
Chain isn't done for, have it & the others sharpened. (few $$bucks for each). Cheap if chains are real dull
![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
Google saw sharpening, or yellow pages in your area or ask around saw shops.
Wrap them individually in an oily rag, put them in a coffee can/lid labeled "sharp xx-inch chains"
Wrap cardboard around 1 or 2 oily rag/chain with duck tape & put one in the saw tool box or carrying case.
You will have enough sharp, rust free chains for years, if you only cut "wood".
TIP: when you hang or store a dirty chain, it has salts & acids from tree sap & your hands, it'll hang there & rust.
If the drive links get rusty, they eat your bar groove & sprocket.
Store in a coffee can with light oil covering the chains until you get them cleaned & sharpened.
If you are going to sharpen them yourself, (PIA to do very many) clean them in gas or solvent first & make sure they are rust free.
Clean again (gas/solvent) to get the metal filings out of the chain & clean the saw bar grove well too (probably some metal filings in it too).
Give them a light oil bath & store individually where they don't get bounced around & nick the cutting tips.
For the money, with that many chains,
Take an "Old Timer's Advice" drop them off at a reputable "saw sharpening shop"
Pick up "almost new sharp chains" in a few days. All teeth are the same angle & height, rakers at the right height.
"Good to go" with several spares.
Learn to file/sharpen chains when you need a break cutting. Have a cup of coffee on the tail gate of your truck,
set the saw on the tail gate, grab a file & make 2 passes on each tooth.
See if you notice improvement after the cup of coffee is gone, of course. You most likey will.
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
