Hi everyone,
I am new to wood stoves this winter, and I've been leaning heavily on this forum as a resource for safe and efficient burning. Thanks for all of your insights because they've been very helpful in getting started.
My questions revolve around strong draft and safe operating flue temperatures.
Location is northern Vermont. Setup (from the stove/ground up):
My questions/concerns in order of priority are:
If the draft is too strong, the only solutions I've read about are i) lowering chimney, or ii) installing a key damper. I could potentially lower the chimney ~1-2' and stay within the 3-2-10 code, but I don't know if that small amount would make much of a difference. My installers were opposed to a key damper, and I'm not even sure if there's space to fit one around the flue offset box and block off plate, although maybe that's what's needed to control the draft and settle the burn/get rid of the whistle.
I appreciate any advice and insights!
![Strong Draft and Flue Temps Strong Draft and Flue Temps](https://www.hearth.com/talk/data/attachments/325/325103-5a232911ffdd3ffeb1985003b8cfa6ac.jpg)
![Strong Draft and Flue Temps Strong Draft and Flue Temps](https://www.hearth.com/talk/data/attachments/325/325104-269e095b2ea8b690851f271ba62ad30d.jpg)
![Strong Draft and Flue Temps Strong Draft and Flue Temps](https://www.hearth.com/talk/data/attachments/325/325105-1e4cd72fdc9f57ca5a1f377e5c2c28d8.jpg)
![Strong Draft and Flue Temps Strong Draft and Flue Temps](https://www.hearth.com/talk/data/attachments/325/325106-1212a8374a12b0302c6bdb74598b0d4b.jpg)
- Lopi Evergreen NexGen-Fyre Insert (EPA certified, non-catalytic wood stove) set in a fireplace hearth
- There is an aftermarket blower attached, ~260+ CFM (fireplaceblowersonline.com: part #9900123). It typically runs on medium to high while the stove is burning.
- Flue offset connector box bridging the stove to the bottom of the stainless steel liner (couldn't fit/connect without it)
- ~27' of 6" stainless steel liner (type 316) professionally installed by the stove retailer (Note: the liner setup is a bit strange, so I'll try my best to explain below)
- The first ~5' of liner from the stove goes up through the old fireplace damper, which was removed to make space for the liner, and to the bottom of the prior owner's stainless steel metal chimney. This section is filled with rock wool I installed along with a block off plate following this website's guidelines and instructions.
- The rest of the 6" liner runs through the Metalbestos (now Selkirk brand) Model SS 8" stainless steel chimney (pre-2100 UL rating, so rated for 1700). It has an offset (maybe 30 degrees?) halfway up in the middle.
- Within this 8" stainless steel chimney, the first ~8' (closer to the stove) is uninsulated up to the offset because the 6" insulated liner wouldn't fit. The 6" liner just runs through the 8" insulated stainless steel chimney.
- Past the offset, there's another ~8' of chimney up to the roof. In this section, the 6" liner is insulated (installers hand-wrapped and glued on faced insulation) within the 8" insulated stainless steel chimney.
- The remaining ~4-5' of chimney is at the roof and above. The old chimney was ~2' above the roof, so as a part of the wood stove install, the installers extended with 3' of matching Selkirk 8" chimney to satisfy the 3-2-10 code. The 6" liner is insulated up to the chimney cap.
- Two thermometers magnetically attached
- I have a Condor stovetop thermometer at the manufacturer's recommended placement on top of the Evergreen Insert
- I have a Condor single wall flue thermometer magnetically secured to a screwhead that goes through the bottom of the 6" liner (~4" above the top of the stove, bottom of magnet essentially touches the flue offset box)
- Because of the block off plate, I can't place this thermometer any higher on the liner
- I attached to the screwhead out of convenience because it's magnetic. I've compared the outside of the liner temp to the thermometer on the screwhead with my IR gun, and they're directionally similar temps (only ~10-25 degree difference)
- I attached a few photos:
- Photo #1 shows the stove in equilibrium, firing at ~500 stovetop and ~500 flue temp (~1 hour in after cold start with ~7 splits, ~35 F outside)
- Photo #2 shows the stove at peak, firing at ~650 stovetop and ~650/700 flue temp (~45 minutes in after warm start with ~8 splits, ~35 F outside)
- Photo #3 shows the flue offset connector box to the liner. I had a Rutland 600 degree high temp silicone sealing the liner to the block off plate, but that got melted off the liner, and I realize I probably should've used a 2000F cement.
- Photo #4 shows the inside of the flue offset. The flue thermometer sits right above the top of this picture where the offset connects to the liner.
- Given the setup I outlined above and placement of flue thermometer, what is a safe operating flue temperature?
- I understand that ~250-450 F is ideal for a thermometer placed ~18" above the stove on single wall stove pipe.
- My thermometer reads well past those limits, but it's also on a screwhead ~4" above the stove and very close to the flue offset connector box. I'm wondering if it's picking up temps from the stove and misleading me to think the flue gases are at an unsafe temperature (>1K F continuous).
- I also don't know if the same guidelines for a single wall stove pipe apply to an insert's stainless steel liner
- At peak, my flue thermometer on the outside of the liner will read ~500-650 (maybe even 700) continuous for an hour or more. It can reach that temperature quickly (~20-30 minutes in), and it typically levels off over time to match the stove's temps. For example, an hour in, and the stove could be cruising at 600-650 F, and the flue would read the same. As the fire calms, the stove will stay in the 400-600ish range, and the flue temps will go down to ~300-400. Although sometimes the flue will run ~50 degrees hotter than the stovetop temperatures continuously.
- Am I losing excessive heat up my chimney because of strong draft?
- Our house is ~4K sq. ft., leaky, not insulated well, and runs cold. This issue is mostly separate from the wood stove and is due to many old windows with broken seals, lack of insulation, and aging/warped siding.
- The stove itself sits in a Great Room with ~22 ft. ceilings and lots of windows, so I'm sure there's inevitable heat loss. If I load up ~7-8 splits into the stove and start it with a Super Cedar firestarter (with outside temps in ~30-40F), it is firing strong secondaries within ~10-15 minutes, and I can expect to get ~2-3 good hours of burn out of that load with meaningful heat, plus maybe another ~1-2 hours of some heat before everything's burned down and it's ready for a reload. ~3-5 hours per load feels low relative to others I've seen loading in the morning and at night, with maybe a third in the middle of the day.
- Beyond the safety question of high flue temps in #1, I'm wondering if the stove is heating outside, not inside. We might start at 60 degrees inside and get to 63 degrees at its peak. It's a noticeable improvement, and the heat from the wood is nice. Given how warm other homes nearby us with wood stoves get, though, it doesn't feel like we're getting the full benefit of the wood we're burning. Maybe that's just how it is with a big, leaky house?
- How do I get rid of the annoying whistle when the stove runs or when it's windy outside?
- I called Travis Industries / Lopi, and they said the whistle has happened for other customers with strong draft. They suggested wrapping gasket around the bypass right at the point it meets the stove (where there's a little hole/gap). I did that, and that maybe improved it, but it didn't get rid of the sound like they said it would.
