Stove works WB-140 - identify Indoor Wood Boiler - manual specs etc
IronMan1864
2
Pennsylvania
Hi just picked up the boiler. It’s in great shape and it was used lightly. I’ve tried researching every piece of information name/number on the data tag and I come up with zero. Has anybody heard about this make and model Stoveworks model WB – 140. Maybe this is a knock off or a re-branded major name/brand? See attached photos any information would be appreciated. Thank you
Stove works WB-140 - identify Indoor Wood Boiler - manual specs etc Stove works WB-140 - identify Indoor Wood Boiler - manual specs etc Stove works WB-140 - identify Indoor Wood Boiler - manual specs etc Stove works WB-140 - identify Indoor Wood Boiler - manual specs etc Stove works WB-140 - identify Indoor Wood Boiler - manual specs etc Stove works WB-140 - identify Indoor Wood Boiler - manual specs etc
I hope you like processing wood.
Have seen similar models who's owners are quite open about lots of wood run through for limited heat.
I believe hobby heater started his burning carrier with a similar one.
Reactions: IronMan1864
I’m just getting started with wood hot water….super green rookie. Just needed an entry point…this was $200. Plan to set up pipe/exchanger with provisions to go modern wood burner or gasification some day. I’ll probably even set this up outside on a good platform and cheap cover and run lines down to the oil burner through the window well. This until I decide where I want to go next.
So any comments from the board are very welcome!
