stove will not turn on
will194859
2
central indiana
i have a st crovix stove an after 1 year of use it just stop call the factor for help an was told to call arep in my aera.50 miles away but all i get is a voice mail,i don't where to get help or parts from too fix .do you know where to get a how too book to fix.? thanks bill
Try unplugging the stove from the outlet and allow to sit for a few minutes then plug it back in and see if ity resets itself. Also try spell check when responding. What model st croix do you have??? when you say it won't start do you mean no lights nothing??? More info is better. Maybe a viagra????
Willy, I have to go along with what Woodsman23 said above. More information would be great! Go to the link provided above as well, because there you should find the owner's manual. Especially let us know if there are any of the leds blinking or whatever.
Good Luck! :coolsmirk:
fuse is a possibility, most will be on input to stove so if its blown there will be no lights or anything , is the stove not showing any power at all or simply will not light, does any component power up at all?
CZARCAR said:
hearthtools said:
CZARCAR said:
fuse within?
CZARCAR,
Please post relevant info.
look 2 holtons post,eh= i aint posting relevent info xcept for first post on this thread beacause post originated in hearth room & not pellet room & hopefully that is what youre reffering to.
on a relayvant note=check electric supply to stove including possible malfunctioning surge protector
Yes what I was talking about was
stove wont turn on ?= is the wood hard enuff?
CZARCAR said:
hearthtools said:
CZARCAR said:
hearthtools said:
CZARCAR said:
fuse within?
CZARCAR,
seems u quoted the wrong post from me
It does not Matter if I quoted the wrong post or not. 30% of your post are short one liners that just clutter up the forums
Well i have a prescot xl ,and it had a fuse burned out ..But now pellets just keep coming down an putting out the fire,What should i do how.. thanks Will
Won't turn on or won't run?
If it won't run, try cleaning out your tee. 9 times out of 10 that's the problem.
