I have completed the break-in of a new PE t6 pics (https://www.hearth.com/econtent/index.php/forums/viewthread/23542/). Since the heating season is nearing, I and am interested in learning other users thoughts on stove top temperatures with their PE stoves.
1. What is safe maximum stove top temperature? I could not find any temperatures listed with the install manual.
2. Knowing that the following is fuel/draft outside air temp dependent, ~ what air control lever setting do you use to maintain xxx stove top temperature for your "typical" heating needs.
The past few nights I have maintained ~ 450 F (on stove top, not trivet top) at about 1/4 "open" draft control with 2- 4 (4-6" x 18") split hardwood (black cherry + locust). 3000 sq ft raised ceilings, ceiling fans a slowly whirling and temps thruout the different rooms in the house 70 F +- 2, outside temps low 50's F.
-- I read one post from this past yr and a mention was made of a graph of stove top temps, any link to the forum where those graphs ended up would be appreciated.
Otherwise, I am one very satisfied PE t6 owner.
