BeGreen said:Congratulations. Put the thermometer on the stove top, not the trivet. Place it a few inches in front of and to the side of the flue. Left or right side, it doesn't matter. Try to locate it so that you can see the middle of the temp range with the trivet closed.
patrolman467 said:Hey guys, I had my stove partly installed today. The installer has to come back again to finish up. He said that he can bring a flue thermometer and put it in the double wall pipe. Here are my questions. Would a hole in the pipe with the thermometer allow any smoke to leak out into the room? Would you recommend getting this done? If so, where would it look the best , centered in the front just above the stove, on the side, or on the back out of view? Thanks.
