So heres the room, sorry if this gets a bit confusing...
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
The room is 20 X 22, 12'6 peak height. @ bedrooms off the end I'm standing in, adding addl 20 X 10'6.
I'm trying to decide where to put the stove, and specifically whether stovepipe height matters, as in how much is inside VS outside. I think either location would head adequately as they aren't much different, the main difference would be lots more, or less, inside VS outside pipe. Make sense so far?
So the locations...
Location A., basically straight up from the white lampshade on the left. About 24" from the wall, just over 9 ft from the floor. Plenty of room to move it in, out, or sideways, as needed for clearance or whatever.
Location B., almost straight across, maybe 2 ft towards the far window. The stovepipe would be about 2 feet behind the fan blades, about where the exposed 2X4 is. It would actually be just to the right of the peak in this case.
So more extended exterior pipe in A., more exposed interior pipe in B.
My concerns... both locations are close, central location wise, so that's a wash.
I know exterior pipe is more expensive, but that's not a major concern. Neither is aesthetics to me.
My main questions...can I get by with less pipe, overall height wise, with location A? Thinking stove draft here. And if not, how do I anchor what would be a pretty substantial length of outside pipe, it's a brand new steel roof. With location B, seeing as it exits very near the peak, I assume a very short pipe outside...correct?
Either would be a straight run of pipe...this is preferable, right?
Sorry is this is confusing (and for the mess!) ...welcome to my world!
