Stove pipe ???
WidowMaker
149
Central Washington
Can double wall pipe from differant manufactures be inter mixed. Looking to put a wood stove in the man cave in place of current pellet stove. Wanting to buy used pipe on craigslist...
TIA
tfdchief said:
Pipe is UL tested and approved. I would not mix brands. UL didn't get to test them that way.
Thanks tfdchief, I did find this statement on ventingpipe.com website
"Different brands are not compatible with each other 99% of the time. Most local code offices require that you use the same brand throughout the installation. Keep in mind that even if you get the pipe to fit together, it still could be unsafe. Check for a UL listing on compatibility to find out if brand X will work with brand Y "
So I'll take that as a DON"T
