I have a Quadrafire Trekker newly installed. The stove is vented through an existing chimney with a 4” insulated chimney liner, ~20 ft. From the back of the stove to the chimney connection it is 5ft. There is an elbow bend at that point.
House is 1892 victorian. No kitchen or bathroom or attic vents/fans. Unfinished crawl space. Stove is located in the rear of the house but not on an external wall.
When the stove starts up, the box fills with smoke. After a few seconds the smoke gushes out of any unsealed crack in the stove pipe and from the back of the stove. Once the pellets are fully burning, the smoke clears out until the next shutdown/startup cycle. On shutdown the glass gets a thick layer of soot.
I’ve had the installer back out and he sealed some of the gaps in the stove pieces with silicone and made sure the stove was level, and advised trying different trim settings. The trim settings haven’t made a difference so far, I’m still cycling my way through them. I’ve also cracked open the window two inches during startup to no avail.
I’m burning hardwood pellet fuel.
Any ideas on causes or things to check? This is my primary heat for this winter, first year using a pellet stove (or a wood stove for that matter), although I do have another wood stove & chimney if need be.
