I have an Osburn 2200 which will have a fresh air vent to it. I am using the duraplus through wall kit. The through wall pipe will be 3 feet to the junction box then up 9 feet all with the insulated triple wall duraplus SS pipe.
I plan to install the through wall pipe about 6 feet above the stove. So I need to go up 6 feet with the stove pipe, 90 degrees and 18 inches to the wall. With the 90 degree pipe the horizontal pipe will be about 12 inches.
Should I use single or double wall, sound like double wall will reduce the heat in the house but improve the draft. I am more worried about the draft then the loss of heat. But if the experts think the single wall will be fine, it would save me some money.
Also should I seal the pipe and what should I seal it with. I would feel a lot more comfortable with a sealed pipe or is that just crazy to worry about.
So looking for some advice.
