Hi there all, stove newb here (but otherwise fairly handy and technically minded). Just brought in a new Pleasant Hearth 1800 sqft/63000 BTU 6" D wood stove to hook up to an already existing chimney and ceiling/finishing support added previously by previous owners.
I've got about 65" from the stove to the chimney connection. The finishing piece on the ceiling I'm pretty sure is a round Selkirk one, says "TYPE HT" on it.
I'm trying to get all the stove pipe parts in an Ace shopping cart since there's a convenient free pick-up option for me. Trying to figure out what pieces I need from stove to chimney pipe.
But back to the FSP/CSP, I took off what cover they had on the chimney pipe inside the house and found a piece that had been just cut and left in there around the chimney pipe. It rotates freely around the chimney pipe and is kind of an inverted u-shaped collar. It's kept from being removed by the 6" D Selkirk FSP/CSP. After some finagling I decided that I might have to drop the CSP/FSP by unsecuring it from above in the attic space (see pics).
It seems held in pace up there by nails I can probably cut and hammer out.
My main concern is is this Selkirk FSP/CSP supporting the entire chimney and will it come sliding through to the living room below?
If I'm ok to drop the FSP/CSP, what parts do you think I'll need from chimney pipe to stove? I kind of have some parts identified but would like to see what you have to say. Thanks for the help!!
Existing chimney from outside:
![Stove Pipe setup Stove Pipe setup](https://www.hearth.com/talk/data/attachments/284/284172-d881fc43e7b8ed534b7af664d76154f5.jpg)
Looking up at FSP/CSP and free piece:
![Stove Pipe setup Stove Pipe setup](https://www.hearth.com/talk/data/attachments/284/284171-bd4b1ffb30193f57fb953eb9187fb170.jpg)
Attic looking down on FSP/CSP:
![Stove Pipe setup Stove Pipe setup](https://www.hearth.com/talk/data/attachments/284/284173-03522e2bdd44d8014131f890a917cc85.jpg)
