Stove Pipe Joints Leaking
KyleK
9
Iowa
What can I use to seal my pipe joints that will handle the heat? Also, is there an adhesive for the rope gasket on the door?
Normally stove pipe joints are not sealed. Is this to correct a problem?
High temp RTV works well for stove door gaskets. If not available Rutland gasket cement will do.
Yeah, they're leaking smoke
Then you need to address the lack of draft.
A stove pipe should, if it leaks, generally suck in air, not leak smoke.
Of course it's still good to address the leaks because they would/should cool down your flue gases which could result in creosote deposits.
So, can you show pictures of your stove pipe and set up?
Is it all one brand?
How tall is the flue from stove top to chimney cap?
What stove do you use?
They're leaking smoke.
This is not normal be it single or double wall stove pipe, if the pipes are in good condition without damage of any kind and made for wood burning appliances exhausting in a approved healthy functional chimney there should be no smoke. If you had a down draft problem of some kind it would normally exit via the stove door !
Are these pipe sections all of the same model/ brand/manufacturer ?
This smoke phenomenon may be an indicator of a serious underlying problem with your chimney not drawing properly which really needs to be addressed first for your safety, if not already done get it cleaned and inspected by a certified sweep or technician to ensure it is 100% operational.
Was this installation done by a professional ?
Tell us more about the flue installation in detail. The problem is likely elsewhere with the smoke leakage as a symptom. The most common issue is a cap screen getting plugged, but it can be as odd as a nest in the chimney pipe.
And are they all male end of the pipe pointing up or down?
The horizontal piece going out is 2ft double wall going to a 90° elbow and a 4ft stack. It's a homemade 3/8 double wall stove. The flue is about 16in from the stove top. Most of the leaks come out the swivel elbows and the single-double wall joint connections.
  • [Hearth.com] Stove Pipe Joints Leaking
I had it apart to give it it's 2 year sweep, and it really wasn't that bad, but after putting it back together it leaked really bad this time.
Take the stack robber out of the system and things should behave better. They are creosote machines. Draft should improve with its removal.
Also, was any exhaust system running in the house, like a dryer, kitchen or bath fan, etc.? Were any windows or attic doors open upstairs?
The stove is the source of heat, not the flue. However, if the wood is not fully seasoned, then the heat output is going to be a lot less. If this is an old stove without a baffle or secondary burn, it's going to be pretty inefficient. If the basement walls are uninsulated then about 1/3d of the heat is heading outdoors. Add all of these together and it's an uphill battle.
Ok. I'll take that magic heat off and build a baffle. The stove is actually in a block shed. Thank you for the guidance.
Reactions: begreen
How tall outside?
4 ft only? Not enough draft. Either because gases cool to much and/or not enough flue height.
But adding a baffle might further increase the need for draft.
On the other hand if it leaks after you took it apart, you may have applied too much force and bent things a bit... Creating leaks.
With enough draft you'd be creating creosote (because cool air being sucked into), and with insufficient draft you'd get smoke out. Either way, I think it's better to upgrade stove and pipe as suggested above.
Thanks for the douchedick response. I probably wouldn't have asked if I knew everything like you do.
You are in the right place to be irritated with that response not much constructive there. So far you have been really amenable to the good suggestions previous guys have had keep working with them and you will find your setup Burns better.
Do you check the moisture content of your wood? How long has it been split and stacked before burning?
Reactions: KyleK and kborndale
For stove rope gaskets I use copper ultra high temp RTV. You find in the auto parts store. It is so much easier than the old stove cement that has been used forever.
