stove pipe damper needed?
kenny chaos
1,995
Rochester,ny
I'll be swapping out the old Riteway for a Lopi Liberty. Should I keep the stove pipe damper or eliminate it?
Thanks-
Ken
Can you describe the flue setup? That's what usually determines the need for a damper.
The flue goes about 15' straight up. I was thinking that messing with a flue damper would negate the proper controls on the newer stove?
Lose the damper, you won't need it. Rick
Agreed, run the stove without the damper.
