Hello all!
We have a small home. I want to add a wood burning stove or fireplace for ambiance and also back-up heat. Whatever we put in must have a small footprint, as we simply do not have a lot of square feet to give to this addition to our home.
My research so far would indicate that a zero clearance wood burning fireplace could be installed inside a surround of 2 feet by 4 feet, with no additional clearances required. Is that accurate? I had one in a house years ago, but I cannot recall the depth dimension. If so that size is accurate, we could squeeze one in between our bookcases. We have enough space for that, I think.
I know that zero clearance fireplaces are NOT efficient. I did heat a previous home with one many years ago during an extended two week winter blackout, and it did keep the pipes from freezing throughout the house and did provide good warmth in the room where it was located. But they are NOT the best option out there for heating and waste a lot of fuel.
I would prefer to install an efficient wood burning stove, but herein lies my problem. We really cannot give up more square feet. Every stove I have found seems to require a lot more clearance around it, up to several feet
And that makes it impractical for our small space. But I have a feeling I must be missing something. Surely if there are zero clearance fireplaces, there are similar wood burning stoves? But I cannot seem to find it if it exists? Help?
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
