elkimmeg said:
goose it seems you setup is ready to step up into the Ever burn technology of the modern VC non cat stove Either the dutch west line od the encore. Till you have experienced top loading you will never go back to side ever. Why support VC well Americn pride clouds my judgement. All cast iron VC stoves are made in Bethel VT. It saves USA manufacturing jobs mThere are many good stove to choose from but your situation they need to be rear venting
I'd like to step up, but it's a big question of $$$ Since the biggest single reason to replace our stove that hits us personally is the slightly lower wood consumption, but our wood cost is mostly "sweat equity" there isn't any kind of reasonable payback period for the expense. We have other things we are attempting to save for that have much higher priorities, so unless I can get the stove as a gift we will be sticking with the old smoke dragon for now. The gift is a distinct possibility but we won't know until Xmas.
I do have a minor gripe with VC :zip: they need to be more consistent in their specs pages! It is very hard to compare stoves when they give you different sets of numbers! Some of the added specs may be in the manuals, but all the stuff on the VC website are PDF's and I have to go through a lot of hassles to open a PDF at present (I'm working on fixing that, but I'm spending my time here instead of on Gentoo.com...
![Stick Out Tongue :p :p](/talk/styles/default/xenforo/smileys/raspberry.gif)
I hadn't looked much at the NC Encore up to now, but it doesn't seem quite as desirable.... The specs:
Product Specifications - Large Dutchwest (LD)
Btu/h (Max.) 55000 Btu
Efficiency Rating 63 % (EPA Default)
Btu/hr Range EPA Test Method 11,300 to 26,500 Btu/hr
Heating Area (Max) 1000-2400 sq. ft.
Wood Capacity # of lbs 25-30 lbs
Burn Time (Max.) up to 14 hours
Log Length (Max.) 22-24 in.
Cast Iron Construction YES
Refractory YES
Built-in Thermometer NO
Ash Pan YES
Loading Front & Side
Unit Height 32 1/2 in.
Unit Width 29 1/4 in.
Unit Depth 19 in.
Combustion Technology Everburn non-catalytic
Bottom Heat Shield YES
Heat Circulating Fan Optional FK26
Flue Collar Size Round 6 in.
Flue Collar Reversible Yes
ENCORE
Log Length (Max.) 20 in.
Burn Time (Max.) 10 hours
Btu/h (Max.) 40,000 Btu
Btu/hr Range EPA Test Method 10,600-24,050 Btu/hr
Weight 395 lbs.
Heating Area (Max) 1900 sq. ft.
EPA Emissions Rating 0.7 (grams/hr)
Flue Collar Size Oval 8 in.
Flue Collar Reversible YES
Firebox Volume 2.1 cubic feet
Efficiency 68 %
Mobile Home Kit YES, U.S. & Canada
Notice - no dimensions on the Encore - can't compare size
Log length - the LD is better, enough so that I would say the difference is that I would need to recut 20% of my splits with the LD and 80% or more with the Encore.
Burn times - The LD has more.
Wood capacity - can't compare easily since the Encore gives volume, and the LD gives pounds...
Heat output - The LD seems to put out a bit more heat, both in the peak and range numbers. The LD is also rated for more area
Flue size - The LD is 6", it isn't clear if the Encore is 6" or 8" - I need to be 6"
I like the idea of top loading, but I'm used to the side load since it's what I do now, and don't have a problem with it.
Most of the other specs seem to either match or be "I don't really care" items, except for one BIG item - price. I haven't done a bunch of price shopping for either stove, but it looks to me like the Encore is about $500 more from the one spot check I just did at Lehman's (based on TraderG's reccomendation) I prefer the flat black look of the LD to the Encore, and I really don't see that the top load feature is that useful to be worth $500 more for what looks like a smaller stove.
Nothing against the Encore, I just don't think it's as good a fit.
Gooserider
