Hi,
I am building a new construction modern/rustic cabin in Rappahannock County, Virginia. My wife and I have been around and around on wood stoves -- I have been in these forums more than is healthy. We are struggling to find a stove that meets all of our requirements and interests ... I would appreciate your advice and recommendations.
The building:
* 1100 square feet.
* The living area has a shed roof, so call it floor-and-a-half volume (8 ft at low end to 12 ft at high end). The sleeping area has a couple of half-height sleeping lofts.
* Full basement, 1/3 cut into the hillside.
* Modern/tight construction -- spray foam everywhere (including the basement walls) - R49 in the roof.
* We will put in some air handling / duct work to move hot air from the living area to the sleeping areas and pull cold air back to the living area.
* Fully off-grid. Solar power, roof-capture cistern for water, etc.
* No backup or secondary heat. Just the wood stove. (Maybe a small propane heater in the basement to keep the cistern rig from freezing).
* Stovepipe will run straight up through the roof.
Climate and usage:
* It's a weekend place, maybe occasional weeks.
* Fall and spring use is "seasonal" - not too cold. Winters can get cold but not that cold.
* It's a windy and exposed location, especially in the winter and spring.
Requirements and interests (which I would take a redirect on if you think I'm thinking about it wrong):
* Want a non-cat stove, because of our largely seasonal, weekend-y, intermittent use.
* Have been looking at stoves sized for ~1200-1500 sq feet, seem to mostly be 1.5 - 1.6 cu ft fireboxes.
* Prefer cast iron in the hope of sitting around a warm stove in the winter.
* We'll need intake air (direct feed to the firebox) as the house is so tight.
* My wife wants to be able to see the fire, enjoy looking at the fire, see the logs from the side. Her parents have a discontinued wood stove that has a glass front door and a side load door, like the Jotul F500 Oslo, and she wants something like that.
Options we've been looking at:
* The Jotul F35 or F45 -- seems to meet most requirements (non-cat, air intake, sized right), BUT it's a N-S loader. So can't watch the fire from the side.
* Morso 7100B -- E-W loader, but it seems undersized for our space?
* PE Alderlea T4 LE -- seems to meet all criteria, it's an E-W loader.
* Ambiance Outlander 15 or 19 -- again, meets most, it's an E-W loader, but no direct outside air?
Questions we'd appreciate your advice on:
* Are we reasonable to want a non-cat stove? It rules out a bunch of manufacturers.
* How would you think about sizing? e.g. F35 or F45, T4 or T5?
* Do you think E-W loaders are going to make us crazy? We have been spoiled by my in-laws' mini-Oslo functionality.
* Any specific recommendations, either from this list or other stoves we've missed?
* Bonus question: should we use insulated stovepipe through the conditioned space? Seems to help with creosote build-up?
That's a lot. Thanks for any advice you can share. This forum has been super helpful to us narrowing the options.
The building:
* 1100 square feet.
Climate and usage:
As for stoves you probably want to stay around the 2 cu ft range. If nothing more just for the longer burn times in the dead of winter and heating the house. Go T5 or F45 size. Or Blaze King.
