I installed my SS flue pipes on my woodstove and added three screws on each joint plus high temp mastic to seal it better. I supported the flue with the wall brackets so the whole setup is solid. I've read around and found that stainless steel expands 3/8" every 3ft.
-Where does that expansion goes if everything is screwed together?
- The only joints that aren't screwed together are the telescopic pipe and the stove top joint. After lighting it up for the first time i noticed that some paint was removed from the telescopic pipe which moved 1/2" and then went back to it's original position after cooling.
Should i leave it as is to expand freely or screw it down?
I thought of leaving if as is and cover the scratched pipe with another 1"piece of pipe which will seat on the larger diameter part of the telescopic flue and slide with it up and down.
![Stove flue pipe expansion Stove flue pipe expansion](https://www.hearth.com/talk/data/attachments/266/266046-3f048bfc990af86bf754e5ea61e607f9.jpg)
