I've been dialing in my fan speeds to hopefully use the most efficient amount of heat from my stove instead of sending it up the chimney.  I don't have a stove top thermometer, but I do have an Flueguard exit gas thermometer the proper height up my double walled pipe from the stove, and my stove came with a catalyst thermometer.
I have a Green Mountain 60 and been aiming for ~400 exit gas temps (on the lower end of the optimal operation temp). My chimney goes straight up double walled the whole way (more info in signature).
The fan noise becomes annoying, but I'm hoping this is the best way to get the most heat from my stove. We had a subzero few days recently and had it cranked as hot as I could but had to fall back on my home furnace to keep us warm.
I do notice the flue gases will dip to ~300+ and into the "too cool" region but my catalyst temps are 1/2 - 3/4 up to "too hot", so I often lower the fan speeds to compensate. I'm surprised my catalyst temps are that hot when the exit gas temps are read barely 2 feet directly above that catalyst?!
Firstly, am I correct in my method using the fan? Regarding having "too cool" flue temps while my catalyst reads over 1/2 way in the optimum zone, does a stove pull that much heat off the flue flange? Or maybe I'm just reading too much into everything.
