My old stove was rated at a max output of 40K BTU/hr. The house size is 2,600 sq. ft., with the stove centrally located, but we use it only for warming up the family room on winter evenings (room is about 20x20). On those rare occasions when we lose power in the winter, we can keep the entire house at a reasonable temperature with the stove. The stove responded fairly well to cutting back the air supply so we didn't get driven out of the room where the stove is located.
It's time for a replacement stove and we wanted to stick with a top-loader design and have been looking at the Lopi Leyden and the Quadra-Fire Isle Royale. Those are rated at 73K BTU and 66.7K BTU respectively, quite a bit higher than my old stove. I have no feel at all for how that higher potential heat output will work in my situation. Will I be able to effectively control the heat output on either of those stoves by reducing the air intake so as not to overheat the immediate area? Hearth size and clearances are compatible with my existing stove, so no issues there. Night time winter temperatures here in central NC are somewhat mild and we don't use the stove overnight or during the day time, so burn times and overall efficiency are not prime concerns.
