New member. I just installed a pair of Regency's, with some "interesting" issues ... but more on that some other time
Stoves are running, but I'm still working on fine-tuning the design. The outside air still needs to be hooked up for both, but in testing the setup I ran into an odd issue.
When I put my hand over the air intake pipe on the back of the stove, the flame changes only a little. It appears there are some other openings that allow room air to keep flowing into the burn pot. I believe the stove is designed like this on purpose, but doesn't that kind of defeat the purpose of adding outside air in a leaky house because it will pull in air through both at any time? (I get that it helps in tight houses, because the hookup is the only low-resistance air intake).
Are all stoves designed like this, or do some have a tighter air intake?
