I have been using my Jotul 550 Rockland for 6 seasons now. I have had a couple of accidentally overfires. Slight glow to stove top for short period of time. A few yrs ago I noticed that face of stove bows slightly outward. This is noticed when looking down at stovecwith door open. My chimney guy says it looks fine. I wouldn’t think that those brief overfiring ms would cause damage.
Earlier this season I was noticing fires becoming harder to control and temps beginning to exceed 800 as measured on stove top front in slot where the warm air comes out. To rule out things properly I replaced the door gasket and stove became much more moderate with temps and I figured I was good. The last few nights I have been noticing that same old pattern with temps getting high (around 800). Of note is that when I start up with a super cedar fire starter in the beginning, the first small load of wood burns with controlled moderate heat about 600. In last couple of night I have been doing warmer to hot reloads with splits about 3-4 inches in diameter. Filling stove about 2/3 full. I could definitely wait to reload longer but i feel like I could have done the same hot reload a month ago with no problem. Tonight I had turned air down early as a bit of a test. Initially there was no flame. Flame very slowly progressed. Short while after secondaries kicked in the flames really got going with blooms of flame up front that would flare up every few seconds. Looked similar to problems I had earlier in season. While it took a while to get going, the fire progressed to in the area of high 700’s to 800 I have 2 stove top therms, each a couple inches off of center and about an inch from the front. I have air turned down all the way when doing this. Chimney is only about 14 ft tall.
I am really disappointed that this stove has that slight warping in the front. I suspect that is the issue causing door to not seal completely as designed. This front face of stove is cast iron and rest of stove body is steel. For all the good reviews on Jotul, I have to say this doesn’t seem like my experience. Way past warranty when I first noticed this.
I know that Jotul sells the replacement stove face and door but it’s over 1k.
What are people thought on this? Thanks in advance. Not sure if video I attached is viewable to all but it was taken when flames seemed to be at their highest tonight.
