I just read that with baseboard heat, any stored heat has to remain at 150. Is this true, and is it not worth the effort to install storage?
trehugr said:I just read that with baseboard heat, any stored heat has to remain at 150. Is this true, and is it not worth the effort to install storage?
trehugr said:so does that mean I can/ should use storage, just more of it? Would pressure make a differance ?
barnartist said:Nofossil, Trehugr,
Good question, then what is your feeling on an air exchanger. Would you say that if you were to rate these, would you order them:
3. Air Exchanger
2. Baseboard
1. Radiant
#1 being easiest on btu's and stretching out a charged storage bank?
Don L said:Everyone I have asked have told me that you have to maintain high heat 135 degree F. and above too support water to air plenum heating. In our previous home we heated the house using a ground source heat pump with an air plenum. The air temperature coming directly off the plenum never was more than 90 degrees F. and the house was always warm and comfortable even in the coldest weather. How come?
nofossil said:Don L said:Everyone I have asked have told me that you have to maintain high heat 135 degree F. and above too support water to air plenum heating. In our previous home we heated the house using a ground source heat pump with an air plenum. The air temperature coming directly off the plenum never was more than 90 degrees F. and the house was always warm and comfortable even in the coldest weather. How come?
I'm venturing outside my actual experience here, but that's never stopped me....
I suspect that liquid-to-air heat exchangers have a higher delta between the liquid and the air than you would have with liquid-to-liquid. Perhaps 135 degree water is necessary to get 90 degree air. The working fluid in your heat pump might well be 135 or so in order to get the 90 degree air. In any event, the net result is that there is less usable heat in a storage tank if you're using a water-to-air heat exchanger to extract it.
Now someone is going to point out that baseboards are in fact water-to-air heat exchangers, and that their uncle Louie had a heat exchanger where the output temperature exceeded the input temperature, and this will spiral off into the weeds. In the meantime, I hope this helps.
jebatty said:Just a note on my experience with a water to air hx unit heater (Modine) in my shop which is fed from storage and alternatively on a direct bypass from the boiler.
I get usable heat from the hx with water feed temp as low as 100. If shop air temp is 60, a hour or so with water from storage at 100-110 will bring the shop up to 70. Poorly insulated shop; 20 x 40 x 10.
