flyingcow said:
north of 60 said:
Without pressurizing your storage you will have to have it located above the highest point ABOVE your heating system or only above the boiler if you are using a heat exchanger. Also think of freezing for storage location.
N of 60
I probably misunderstood. But my tank is about 5 to 6ft below my boiler. Distance between boiler and tank is about 100ft. Works fine.
Height of unpressurized storage in relation to boiler would only matter if you were running the same water in both boiler and storage tank, without a heat exchanger in between.
With most boilers, you wouldn't want to do that anyway, as, under such conditions, you're likely to have (and keep) a lot of oxygen in the boiler water, leading to premature corrosion of the boiler.
Once you have some type of heat exchanger separating the boiler water from the storage tank water, vertical difference in having the tank below the boiler becomes mostly irrelevant, unless you were talking huge vertical differences.
