Getting ready to insulate my 1000 gallon propane tank. Here are the options I have come up with from this bulletin board past threads and some hybrid ideas:
I will frame a box around three sides of the tank, it sits in the corner of my shop so two exterior walls the the floor slab will be the other sides
Then I will staple a radiant barrier foil to the inside of the studs and to the sheetrock on the exterior/existing walls I have a roll left from my staple up in floor heat I figure it can't hurt anything and will be one more layer to help block air movement
There is a contractor that does blown in cellulose insulation, this would seem to be the least labor intensive, fill the inside of the box with cellulose minus blocked out areas for access to openings and drain valves. Then put Batt insulation in box framing and skin with plywood
or
Get Batt insulation in rolls and spiral the tank, possibly use some kind of spray adhesive to stick batts to ends of propane tank, do a couple lavers then wrap with chicken wire to hold everything in place. then stuff all the voids in the box with batt insulation, definately more labor.
If I have "chases" to all openings....potential leak spots probably just boxed out areas around plugs and valves with a removable panel, also filled with insulation which I could simply pull out to get at fittings and sensors, same deal with the fill/drain, removable panel in plywood skin, boxed in then stuffed with batt insulation for remove on use or inspection
What are the pros and cons of the above options, I also have 2 in pink foam board I thought about putting against the walls of the box, they are leftover, I saw on here that they can't handle the heat so there would be cellulose or fiberglass in contact with the tank and the rigid foam would be the outer skin no contact with tank and probably 8 inches away at closest point
I would caulk all the seams on the outer skin of plywood, tape all the foil seams and try to make shell as air tight as possible
This is a decent project and insulation isn't cheap so I don't want to fail or have to do it again later so any advice is greatly appreciated
Laters
or
Laters
