woodsmaster said:Did you put drains on the bottom of the tanks ? I didn't on mine, but wished I had when I flushed every thing out.
Are the pipes on the top of the tanks just for filling and letting air out ?
Clarkbug said:Looking good Huff! I wish I had the headroom that you have in your boiler room.
I also installed dip tubes in my tanks to make sure I could use the space at the top and the bottom for storage instead of it just ending up as dead space. Then again, you have more storage than I do, so its probably not an issue.
RobC said:Huff you might want to put a simple coin vent on top of tank the float types can leak.
huffdawg said:Tested storage loop @ 70 psi. water pressure no leaks. Now filling one storage tank. I have one sx 110 amtrol exp. tank , does that seem like enough for roughly 680 gals total water volume
huffdawg said:RobC said:Huff you might want to put a simple coin vent on top of tank the float types can leak.
I have 6 float type air vents on my system already. oh,oh. But no leaks so far
Pete Schiller said:Taco makes a waste connector (Taco #414) for their Hy-Vent float style vents. Here's their description: "The Hy-Vent® Waste Connector screws onto the outlet connection of the Hy-Vents (models 400, 426, 418, 416) to provide a worry-free installation. The 1/4†threads easily connect to a waste line, preventing water damage if the vent ever leaks."
Has anyone used those or made their own to monitor the vents for weeping? I'm thinking about using blown in cellulose to insulate my tanks, but I'm concerned about any leaks that may develop.
goosegunner said:Very nice looking install!
I am wondering if you might get air where your copper connects to the black iron 90 and drops straight down.
I have a similar drop in my lines that connect to my storage. I can sometimes here gurgling there. Mine is piped like the simple pressurized storage sticky. It is more pronounced when the load pump kicks on to send water to the house. I will be adding a vent in the spring.
gg
huffdawg said:I just filled the supply and return piping to the ball valves on the storage tank I had zero leaks on the anything I soldered but I have leaks on every copper union but one that I installed . do you need to use a four foot snipe on the wrenches or what >:-( .
In the pic to the far right . is a fourway flow direction valve for charging and recovery of storage and buffer tanks.
Huff
kopeck said:huffdawg said:I just filled the supply and return piping to the ball valves on the storage tank I had zero leaks on the anything I soldered but I have leaks on every copper union but one that I installed . do you need to use a four foot snipe on the wrenches or what >:-( .
Huff
Where did you get your unions? K
salecker said:Hi Huff
Looking good
I have just one observation.
When i was told about plumbing my tanks,i was told to do a reverse return series??Not sure if that is the right term.Anyhow on yours the supply and return are the same teed into about the middle of the tanks.I I was told to go in the top into tank 1 then tank 2 then come out of the bottom return from tank2 then pickup tank 1.I was told that water was lazy and will take the easyest path.By doing a reverse series you force the tanks to charge evenly.Seems to work i can't measure any differace betwwen the tanks.
Just my .02 hopefully befor you can't change anything
Thomas
Looking good
Thomas
RobC said:Between top and bottom is where I have had leaks not out the vent it self. Even when they have been tightened up they still work loose over time with the expansion and contraction. If this happens it makes a lot more mess than just a weeping vent.
Mine are located where you can't really get at them and they're there just to purge from high spot in system. For me coin vents works just as well.
huffdawg said:I got them from the wholesale plumbing supply here . I took them apart yesterday and applied thread sealer to the seats. all water tight now![]()
