Has anyone thought about using ferrocement for a storage tank? Cheap to build---easy to to vary size--- one or two walls of basement already there. Any issues of waterproofing?
ssfein
ssfein
free75degrees said:I am using 2 layers of 2inch polyiso inside of my tank, which is half below basement slab, half wood frame above slab. I put the epdm inside of the polyiso. The polyiso is fairly fragile when it comes to very localized pressure, like getting bumped or being stood on, but can easily support the water pressure since it is so spread out. When I had to get inside the tank I would put some scap pieces of polyiso on the floor and stand on them to avoid damage. This past weekend I put in the epdm and filled the tank almost full. Everyhting looks good so far, although it will be a bit of a challenge to deal with the excess epdm in the corners. I think I am going to use hose clamps to bunch them up tight in each corner, then cut off the excess above the water line. I plan on posting pics soon...
WoodNotOil said:Having it in the house may require less insulation if it is in at least a partially heated space and as you said it is closer to the demand for heat. I don't think the water would get that funky. If you use coils, keep a sump pump around to drain it with. If you use a plate hx like I am going to do, putting a purging valve after the pump that pulls water from the bottom of the tank would probably allow the pump so empty the tank as well.
