I've been reading all the threads on power failure for the tarm 40, please correct me if I'm wrong. a dump zone is the first line of defence in a power failure. what is the difference between a dump zone and a gravity feed zone with an automag? are these both the same things? If I understand it correctly the gravity zone has to be installed without any bends or changes in elevation, restrictions, and placed above the boiler. some have a cast iron radiator in use for there dump zone, seems like there would be restrictions in a cast iron radiator. others talk about a thermo-siphon loop to a tank above the boiler for an overheat situation. 25' of fin tube seems to be what everyone uses. or possibly a pressure hot water tank. a heating zone will not work because of the restriction ? can a heating zone without restrictions be used as a dump zone? or is this impossible. what to do about a pump failure? automag to the overheat loop which is the same as a dump zone???  it's my lack of plumber terminology. please get me straight on the different words and what they mean. thanks sweetheat
