I have a little MS 170 that usually sits on the front of my ATV and gets very little love and is really only used for cutting trees when out on the trail. Last year i replaced the bar and chain and never really though of it until today that it has never really cut as nice as my old chain and bar, but i thought it just needed a good sharpening. Yesterday i decided to cut a stump down to ground lever and was probably a bit more than i should have been doing with this saw. The issue was i could get nothing but sawdust when i was trying to make cuts unless i was using the tip or using the top side of the bar then i was getting nice long shavings like i should have been (heck my old chain/bar cut better and it had been sharpened so much i was missing teeth). Im not stranger to sharpening and can always get a nice sharp chain by hand or using my sthil 2 in one sharpener, i usually always use the sthil sharpener as its just easier to get a good quick sharpen. I thought maybe the rackers were to long and filed them down a bit more and that made no difference.. It also tends to pull to the right but i think that's just the way i hold the saw as i grip more to the right so im probably putting a twist in it. So its it possible i just got a messed up chain right from the get go, i also noticed that it is completely missing a tooth and i do not remember having a gap like that in my old chain.
I should have just been smart and used a buddies falling saw and just purchased him a new chain when i was done as it would have kissed the dirt a few times.. If the saw would have cut like it normally does i would have been done in a hour and not 4 hours later and 5 tanks of fuel.. LOL
Was not a good day for gas power equipment, it was a real bear to get the saw running it seemed like it was flooding and took me a while after starting to get it to build up RPM. Plug was dry and looked good but going to grab a fresh plug and filter for it today.. Same with my leaf blower always a PIA to start right from new and its sthil as well..
