Any suggestions for the angles when using an Oregon sharpener to sharpen a Stihl chain? Any help would be greatly appreciated.
You may very well be right. I usually just eyeball my Dremel up with the little pre-stamped 'line' in the top of the cutters......Scotty , pretty sure that most stihl chain (at least rm & rs ) use a 30 * angle on the cutter with no offset from 90 * to the bar .
Could be wrong though , as i just learned from an earlier post that i have been " seasoning" wood all wrong , and will likely have to sell it for mulch .![]()
Well, i cheated..... I read the spec sheet for one of my RS chains .........You may very well be right. I usually just eyeball my Dremel up with the little pre-stamped 'line' in the top of the cutters......![]()
naaaw....as long as there was a picture or two on the flyer, yer good!Well, i cheated..... I read the spec sheet for one of my RS chains .........
Btw .... Is reading instructions still a man card violation ?![]()
Woah! You ask for directions ?! And, admit it ? I've got a long way to go then in my journey to enlightenment.Come on Nix - we play with chainsaws!! I even ask for directions now and then and I have no concerns for man card revocation!
Who makes the chain , and is it chisel or semichisel ?Might just be me but i find a 35 degree angle works best .
Hey, that's all that counts in the end .Stihl Will have to look at the box later . Like i said , it might just be me but i like a 35 degree angle
LOL what post was that? missed that one.i have been " seasoning" wood all wrong , and will likely have to sell it for mulch
Ok, time again for this newbie to learn something...my Husky I know is 30...why would a Stihl be different?pretty sure that most stihl chain (at least rm & rs ) use a 30 * angle on the cutter
Check ralphs thread on drying wood in the woodshed forum .LOL what post was that? missed that one.
Various chain manufactures call for different specs . It even varies by chain type . To specifically answer you question .....Ok, time again for this newbie to learn something...my Husky I know is 30...why would a Stihl be different?
Not to take this thread off course too far , buy MM where is the finish to the 460 thread ?30/60/0 is pretty standard for most chain. That's what I default to when the chain type/specs are unknown.
Don't forget the rakers . Their depth has ab great influence on the cut .Great, thanks for all the tips. I have been fooling around with different angles just can't seem to find a set up that was giving a good edge. I can draw blood an an Oregon chain just by running your finger over it. That same angle on the stihl chain was just kinda blunt.
Think I read somewhere that you can go with 35 degrees for the soft stuff and 25 degrees for the hard stuff, but cannot remember where I read it. Thing is, you don't want to continue changing angles on the chain or you will be eating up metal.
