well, into my 4th season burning pellets and after expirimenting every which way I could to try to stay warm and also try to lower pellet consumption, I have given up the ghost....![hmm ;hm ;hm](/talk/styles/default/xenforo/smileys/hmm.gif)
tried all different settings each year, stove mode/ temp set in the high 60's/low 70's,low fan speeds.
same with room mode.. auto/manual. mix it up. all around the dials for weeks at a time..
different feed rates etc.
well, with a Big Harman P61A, Your gonna use a certain minimum amount if you want to have a very warm house. unless u live in a closet or a 1 room cabin..
like 74 degrees or so...
my house is not well insulated.. more windows than wall space..Insulated glass but like 24 windows..
[old 1920's 2 story..[not gonna knock out windows just to put walls in place] kinda bass akwards I think.
..love the views..
I use good to excellent pellets, hardwood and Soft, but still, my stoves has a big burnpot...
a big burnpot holds lots of pellets.. lot's of pellets fall out of the hopper to fill that burnpot....anyways,
all this winter I have kept my stove on room mode auto...74 degrees temp set/ half fan speed.feed rate# 3 or 4 depending on small or longer pellets.
house has been consistantly warm all winter and my pellet consumption thru out cold spells where as the stove would be running 24/7 has been approx 12 hours per bag....2 bags per 24hrs at these 35 degrees or lower days/nights.Best I can do.... less consumption of course during shoulder season.
heat makes it upstairs and is a brisk 66 degrees.. fine for sleeping.
even used douglas firs, which are hands down the hottest cleanest pellets I have used with just about zero ash give me [maybe] an extra hour/half of burn time.. same as Hamer Hot ones].....
and of course, if you have a house that is tight as a baby's but, I'm sure you get lot better mileage.with the P61 Beast..!!..
also might mention I had the oil tank filled Sept '2016 and have used half tank since for domestic hot water.
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
