Finally we brought the fireplace inside the house. Quite a challenge to handle the 600lbs "beast" but we did it. Also, I got a chance to start the frame.
The question which I have is about the adaptor plate. I bought the chimney adaptor plate from the supplier but doesn't work because the pipe is raised above the top of the fireplace and it will create a gap so not possible to seal. Looks like I need to use it together with the adaptor plate which came with the fireplace. Is this correct? Do I need to use cement I assume in order to have a perfect seal? Here are a couple of pictures.
Hey I am in the same boat you were in I purchased the anchor plate and tested fit it the other night the anchor plate does not fit right in the top of the fp30 wondering if you ran into the same issue and just sealed it with cement thank you
