Stainless Stove
Bill
584
South Western Wisconsin
If stainless is very durable, gets hot fast, reflects heat, could burn off gases, doesn't rust, and is often used in secondary combustion, how come they don't line the inside of the wood stove with it?
Better yet, why dont they build a 316 stove?
Too bad they can't mak'em from magnesium-then little old ladies could swap out a stove by themselves! :cheese:
Stainless, depending on grade, is $1.50 to $4.00 or more (fancy grades).
Firebrick is very cheap - maybe 30 cents a brick.
But a bigger reason may be that stainless allows heat to transfer through it, while firebrick reflects inward and allows for higher temps and cleaner combustion..thereby allowing a stove to pass EPA standards easier.
It is possible that stainless could be used for afterburners in certain stove - in fact, I think it is used for baffles and some secondary tubes.
I would like to know were you can get bricks for 30 cents , around here they are $3 a piece .
I'm talking manufacturer prices - have not bought in a decade or so, but I used to get small quantities of split bricks for about 60 cents....not as an OEM, but buying them delivered by a masonry yard.
30 cents may be a little low, but I'd guess manufacturers are paying well less than a buck for splits (1/2 firebricks used in stoves).
I'm a bit behind the times as I have not been in the physical stove biz for about 8 years now (sold my shop in 1998).
The stainless prices I gave are also quantity prices for manufacturers....although the spread on metals is not usually as much - you can buy some stainless sheet on ebay for 2 bucks a pound plus shipping.
yes you're right , they do use stainless in secondary tubes , and i think a stainless stove is not practical .
Think about it too, the regular steel stoves seem to last forever as is makes me think it would be kinda hard to justify the overall cost of a completely stainless stove.
However, imagine how neat a non painted stainless stove would look after being fire a while. All rainbow colored and such. Oh well, guess I just like the way metal looks.
hard to keep clean dow.
I picked up bricks for about a buck and a half each from the local concrete yard.
Matt
stainless would be impractical due to not only material cost, but also you would not be able to weld it with mig machines and wire, would likely have to be tig welded which is a more time intensive procedure, as well as one which requires a high degree of skill. there are other concerns as well already mentioned in this thread, but looking from a manufacturers standpoint the cost of materials and labor time per unit would make for an extremely costly unit. i do not think any manufacturer would attempt to field a line of this type for these reasons alone , much less so looking at the points raised about refractory rates and heat transparency
I certainly hope anyone welding on a box that holds fire in someones home is highly skilled. Stainless is steel, plain and simple and if the people are trained properly the weld is the last thing anyone should worry about. Exhaust systems in boats go through 10 times the stress a wood stove would put on any weld/seam.
I keep thinking about the delorean. With the spread on wood stoves being very broad such as a 1200 dollar osburn to a 3100$ Hearthstone, there should be room for some alternative metals. Really though, the steel plate doesn't seem to wear out so whay bother?
Oh, and I can buy stainless steel welding rods for my arc welder, made of nickel or something. Nothing magical about stainless.
Stainless is great to spot weld - and also electron beam weld. So we can have a spot welded stove!
Heck, it works fine for cars. If stainless was used, a stove might be able to be much thinner and lighter, which would make up for some of the price diff. Then you still have the paint problems.....cause the surface of stainless is generally smoother - chrome and nickel in it.
You would also burn your skin easier on it.
Paint? I like Cories thinking, rainbows are cool dude
--And a stainless Delorean woodstove would offer time travel when it reached 88*F -or was that mph? :coolgrin:
Aren't some of the new European stoves clad in stainless? At least that's what they look like. If there wasn't a fire burning in them you might think it's a circular refrigerator.
Pacific makes this
  • [Hearth.com] Stainless Stove
I was thinking more of lining the with ss, wouldn't have to welded, could be stainless panels. You could put fire brick behind the SS. I just thought it would reflect the light from the fire better, burn off the gases faster, heat up faster, burn cleaner, burn hotter, but then again maybe it wouldn't.
I wasn't thinking of ss on the outside, but maybe you could chrome it. The thought of a chrome stove makes me laugh.
Hey maybe there's a developing market here....I could sell chromed-out stoves cw oversized doors and legs to the hip-hop crowd;investors line up here!IMPO too much shiny stuff is ugly,yet I'm a sucker for titanium or gun-metal grey.
yes begreen, Napoleon oil stove have stainless steel mirrors to reflect the heat into the room.
Stainless steel is a relatively poor heat conductor. As a result, stainless steel cookware is generally made with a disk of copper or aluminium in or on the base to conduct the heat across the base. Go take a careful look at your stainless steel pots and pans.
This makes it great for secondary combustion chambers, burn tubes, and chimneys (in all cases where you want to "trap in" the high temps) but bad if you actually want to put heat into the room (i.e. for the stove itself).
no need to spot weld , stainless is weldable with a tig welder . and if you look at sum of these out side boilers, they are using stainless in the fire box. I just think that they would discolor and you wold not be able to maintain it appears. For instance, i have a stainless steal toaster oven and this thing is hard to keep clean after a wile it looks grows .
