Hello,
Looking for some help on how stainless steel liner should be installed. I had a installer come out and perform the work, but when putting the stove pipe on it was put with the male ends facing down so I had questions about the rest of the installation. I took stove pipe apart to ensure running the correct way and noticed there was not a tee cap put on the end of the tee. Installer said this was for easy clean out. After reading on this site I realized this is incorrect, even if convenient. I then had a chimney sweep come as I no longer trusted installer and sweep said is his report "The liner does not extend to the base of the chimney and there is no bottom cap at the base of the tee. The thimble is not cemented in. It does not appear that there is the proper insulation installed around the liner. This can all contribute to poor draft and be a potential fire hazard. This does not meet building code." Stated the job would need to be re-done.
Background about wood stove/chimney: Built in Maine 1997 with clay lining, receive word that it was cracked after inspection/clean, told to get stainless steel liner. Chimney cleanout is in the basement, wood stove little moe all nighter is on first floor sitting on brick, with chimney then extending up through middle of living room with high ceilings/beams then through attic then roof. I sleep on second floor with staircase that goes up behind chimney that leads to a room almost like a loft where I can look down on the stove. Boiler is in basement and runs on other flue in chimney.
Can anyone answer how proper installation/insulation should be completed? I want to instruct the installer to come back and complete correctly with information from sweep but am not sure what is best and make sure done correctly, as no longer fully trust work being done. Does the liner need to run to the basement clean out, then cap installed there? Does the clay flue need to be taken out if cracked before liner & insulation put in? Included photo of cracked flue. Thank you.
![Stainless Steel Liner Installment Gone Wrong Stainless Steel Liner Installment Gone Wrong](https://www.hearth.com/talk/data/attachments/304/304726-c72180630cfd66d48ba89197a1d144ef.jpg)
