Hello everyone,
I have a question regarding stainless pipe passing through floor joist space before I finish the chase. I recently had a bad block chimney removed and have installed stainless pipe in it's chase. The woodstove is in my family room in my basement and the pipe travels through the floor joist through a framed in first floor chase to the attic (single story home with walkout basement). I installed the pipe following the manufacturers instructions with the ceiling support in the basement and insulation shield/firestop in the attic. I may be overthinking it but should there be a joist shield in the joist space along with the ceiling support? The pipe has a required 2" clearance to combustibles which I have 3" to the closest combustible which would be the floor joist (firestop drywall in the chase also has 3" clearance to the nearest point). I fabricated a shield I think would help reflect radiant heat back to the pipe in that wood floor joist space but maybe it is not needed with this setup (pictures with and without my fabricated shield).
The joist shields state "The firestop joist shield is used in floor & ceiling penetration installs that do not include a ceiling support" which would indicate it should be ok without a shield?
Thank you!
![Stainless pipe through floor joist question Stainless pipe through floor joist question](https://www.hearth.com/talk/data/attachments/317/317784-4161eeed557c312f4cf785b339aeb6c1.jpg)
Thank you!
![Stainless pipe through floor joist question Stainless pipe through floor joist question](https://www.hearth.com/talk/data/attachments/317/317783-38361f067344b28a8e9b5a894ba822df.jpg)
