Stainless Liner Poor Wear and Install Key Damper?
Hexa Fox
200
West Virginia
Hey guys,
Posted awhile ago about this and there was at least some thoughts of me having too strong of a draft. I bought a stainless liner from Duravent and a brand new Englander 32-NC last year. Either way I experienced what I think was a lot of creosote buildup and more wear than is probably normal on the liner as well. I was hoping to get some feedback on both of these things.
1.) I want to install a double wall key damper like the one linked (stove pipe is already double wall). One of my concerns is that I believe the only way I am going to be able to install it is on pipe that is not vertical. I'm not sure if this is required or will increase my chances of smoke coming back into the house or not. You can see from this picture where I propose the damper. This is what I think I would install.
[Hearth.com] Stainless Liner Poor Wear and Install Key Damper?
2.) I am concerned about the wear I have experienced from this setup being used less than a burning season. I only started burning in it this January and until sometime around April. I plan to pay more attention to the moisture content in my wood but also hope the damper will help too. There were some concerns of my stove burning a little hotter than it should and me not having goo control over it. Having that said, the first two pictures here show my cap and the top piece of oval liner. I have not cleaned it yet. I was hoping that someone could tell me if this just looks like normal wear or if it is indeed excessive? It looks like there is already a good bit of rust and corrosion. I am guessing it is probably okay to use but this top portion concerns me. The last one is the horizontal run through the wall. I also had a picture of what the actual stove pipe but they both seem like they had nice buildup. Thoughts?
[Hearth.com] Stainless Liner Poor Wear and Install Key Damper?[Hearth.com] Stainless Liner Poor Wear and Install Key Damper?[Hearth.com] Stainless Liner Poor Wear and Install Key Damper?
Hey guys,
View attachment 331941View attachment 331942View attachment 331943
What wear are you referring to??? I just see lots of creosote
Reactions: Hexa Fox
I'm not getting the relationship between what is shown, creosote buildup, and adding a key damper. This looks more like either too little draft, damp wood, or the fire being choked down too much.
I'm trying to understand why there would be any rust showing in the upper liner. What product or whose liner is this? Was there a chimney fire last season?
Reactions: Hexa Fox
Hey begreen,
It is the Duraliner oval liner from Duravent. I know you cannot remember everything but I posted here last year while I was actively burning. The thermometer that I choose was indicating that I was basically over heating the stove. You guys recommended an infrared temp gun which showed that the thermometer was around 200 degrees off.
There were still concerns that the stove was getting too hot and I did not have adequate control over it. For instance, after I got a nice fire going I could completely close off the air to the stove and while it helped it seemed like the fire would burn full blast until the wood was coals. My burn times definitely seemed to be less than other feedback that I have gotten too.
Regardless I don't think trying a key damper could hurt. If it turns out to cause more issues it is easily removed since I am not installing it in the pipe and can just remove and replace. However, is it okay to install a key damper on an angle like this that is not perfectly vertical?
Here is a link to one of my discussions with pictures. You can see that the firebox is not even overloaded with wood and the indicator in the second picture seems to be showing 1,000 degrees. So even if it is around 200 degrees off that still puts the stove around 800 and the air is fully closed.
Thanks, I've reading some older threads as a memory refresh. With a basement install, I'm guessing this is a pretty tall liner. A key damper won't hurt and it's ok to put it on the diagonal connector. Have the boost air ports been closed off on the stove?
Reactions: Hexa Fox
You guys helped me calculate the overall rise but I cannot remember exactly what it was. Having that said, from the tee inside the thimble, the chimney rises up almost exactly 17'. I also got an extra 12" or so from the liner protruding out of the chimney. Then add a few feet for the wood stove pipe to the thimble.
Sorry I'm confused, I have never heard of "boost air" on a wood stove? I thought maybe you were talking about where you would attach a blower but I Googled this term and I am even more confused.
You also got me thinking. I thought that a drawback of the Englander that I bought is that it did not have a blower port. I took a picture of the back of mine. Is this a blower port or maybe what you are talking about? I mentioned to you guys once before that my ash drawer has a rather significant gap in it and could be causing this but maybe air is getting through this port?
Boost air feeds the fire for easier and faster startup. However, they are unregulated and can provide too much air in some conditions, once the stove is warmed up. IIRC the boost air ports are small holes on the bottom of the stove right behind the front legs. A wad of aluminum foil or a magnet can be placed over them to test if that makes stove regulation better. There are several older 30-NC threads on this topic.
Reactions: Hexa Fox
I do not see rust, however I suspect a overly choked fire because of all the the creosote at the complete top, possibly insufficiently seasoned wood.
Take an existing split, re-split it in 2, measure your moisture in the middle of the newly fresh opened face with your meter and see what that gives you.
I have 28 feet of exterior chimney, 17 feet of chimney is not very long and most likely not causing an overdraft condition. On my PE I stuffed the 1/2'' boost air hole with new left over 5/8'' door gasket, works extremely well, very safe and easy to do.
Reactions: Hexa Fox
Thanks for the response. I have been looking for something similar on my Englander. If you are facing the stove there is a hole on the lower right side that I would say is probably a little more than a half inch in diameter.
Some of my wood not being properly seasoned could very well be the problem. I burned an assortment of stuff last year and in the past I just burned through the terracotta liner with an old school Fisher stove. Some of the behavior I got from the stove led me to believe the wood was not seasoned enough to be burning.
I know that some of it was properly seasoned though but that wood especially got away from me while burning it. It seemed to burn up very quickly and I was having to load the stove even more often than my old Fisher. I am hoping that a key damper will help me keep better control of it as well as get better burn times. The one I linked is suppose to arrive tomorrow.
The wood that I have in now will give me a bias reading because it has been inside for some time and that first rack is always more seasoned. I still have a good bit of ash that has now been split and stacked for close to two years now. I will carry some of that in next, make a split and try to start getting some readings.
Measure the wood you plan to burn but that you expect to be the worst (youngest, thickest, densest -e.g. oak).
Measuring your best wood might not inform you enough of what it is going to be like this winter....
Reactions: Hexa Fox
2 year old Ash should be super dry and will probably burn very fast, try burning some less seasoned wood mixed in with your Ash.
This year some of my wood is 3 years old and it really is too dry, throws a heck of a lot of heat but burns much faster.
From the look of your chimney you can't choke the stove down anymore. You are either running it incorrectly or you have wet wood. Your chimney should absolutely not look like that.
Reactions: stoveliker
I burn 4 and 5 year old wood this winter. Last year 4 year old wood. It's not too dry for my system.
If it takes off on you, use a key damper as you are planning to, and dial down the air earlier but in steps (not all at once).
