i just bought this stove used its a 2005 model. i cleaned it put pellets in and turned it on but the power button flashes green. it wont feed pellets and wont start the stove...
its a 2005 model i removed the jumper from slot 9 to disable the thermostatOn the control board there's three positions for the stove to operate,manual,T-Stat and smart stat which one is your stove in?the flashing green light indicates a thermostat not calling for heat.If your trying to start the stove in any position but manual without a thermostat it won't start.
its the model before the toogle switch on the control boardBut have you tried running it in manual mode?
i tried it same issue the red light on the fan control#2 blinks after 15 secondsits the model before the toogle switch on the control board
i did try after the jumper was moved same result
+1x2Your combustion fan isn't spinning up to speed no partial vacuum sensed the stove says I ain't going to start and you got to likely clean me really good and free up the combustion blower (if it is a gummed up blower then you might also need to buy a new one).
...... i cleaned it put pellets in and turned it on.......
it was a friends stove in her basement for her .ex's man town she said she would never use it they used it last year i saw it running in april at the end of the seasonAnd what did the "cleaning" consist of? If you just vacuumed out the burn pot & firebox, that's not enough, ESPECIALLY since it's a used stove
Just curious, why did the original owner sell it? Did you see the stove run before buying it?
