St. Croix Prescott - WAY too much flame
scottymon
6
Chambersburg PA
Had 3 year old used stove professionally installed and cleaned last week. Took off thermostat and running on manual control. If I set it above 2 the fire gets huge and flames go up hopper feed. Have tried different damper settings but no difference. Stove is also putting out a good bit of white exhaust smoke. Good active flame on 2 but even on that it reaches the base of the heat exchanger.
Any help appreciated!
I would think the white exhaust smoke is just steam from the outside temps being so cold, not actual smoke.
As you can see from my pic having high flames is fine. I have no advice about the flames going up the pellet chute.
