I recently cleaned my Hastings out for the spring. Took all the ash I could lay my hands and vacuum on out. I also used the leaf blower trick, much to my children's amusement. I came back in and went to turn the stove on just to check that it still worked after all my internal tinkering. I did not take the fans or any other internal workings out of the stove. I used the vacuum to get into them as easily as possible. When I pushed the On/Off button nothing happened. The stove currently has no fuel in it. Should the light have turned on? Is the fuse blown? If it is the later, how do I get the fuse out to change it? Is there something else I should be looking for? Thanks for all you help everyone!
