St Croix Element P
dacboyz
8
WI
This is my issue I start it shuts off doesn't even light and # 3 light comes on. Turn it back on and sometimes it will light but shuts off again same thing # 3 light so I try again and it goes. Problem is I don't seem to be getting much heat out of it no matter what heat level its on. So I called someone and they came and said it was my control board so I replaced it and the same thing happens. I also noticed the sensor eye is not working. How do I fix this? I tried searching but found nothing. Any help or suggestions would be appreciated, I am ready to just junk this stove. Also how do I hook up the thermostat for this?
Is the stove clean from the fresh air intake to the exhaust cap? Try jumping the vacuum switch? Clean the hose from switch to the fire box, including the port in the fire box. #3 light is the proof of fire switch, so if the stove doesn't start then you will get that light.
