I had me insert installed last February so I am relatively new to pellet stoves. I get a very clean burn on setting of 3 and higher but can't use it on 1 or 2 because it burns so dirty. After just an hour I get a creosote stain on the glass and if I burn overnight the entire glass is covered with a thick coating which is difficult to clean off (found if I hold a paper towel against the glass and spray with cleaner - let it sit for a while and then clean it works quite well, but still a lot of work) When I burn on 3 and higher overnight I only get light coating of dust which wipes off. I know there are settings on the St. Croix which I believe are to fine tune the settings but I don't know what I change to improve the situation. Any help will be really appreciated because in my situation, 3 and higher are just too much heat a lot of the time.
Thanks!
Thanks!
