We've had a Heat & Glo fireplace for about 20 years. We don't burn that often, but do enjoy the fire most weeks.
![Squirrel has hidden black walnuts between firebox and outer shell of fireplace, how can I get them out? Squirrel has hidden black walnuts between firebox and outer shell of fireplace, how can I get them out?](https://www.hearth.com/talk/data/attachments/286/286168-fb08b678b3a6f20dea6fad1f0441648a.jpg)
As fall came this year, we had a noise in the house that turned out to be a squirrel coming in through the outside air intake, bringing in black walnuts for the winter. I found that the screen that should have blocked the duct had disappeared. I know we used to have one. I've put some wire mesh over the intake. It won't happen again.
I vacuumed out the black walnuts I could see in the intake vent, and it was solid nuts for 10 feet or more. Beyond where I could reach with the vacuum, I could see more.
Eventually I looked at the fireplace itself. I was able to see through some access holes at the front that there are black walnuts inside the walls of the stove, between the outer shell and the firebox. The squirrel seems to have come all the way along the fresh air intake to this "perfect spot"!
I've consulted my local dealer, and he believes the only solution is to remove the fireplace from the chase, and potentially replace it. It's not clear if the space between the walls could actually be opened up to remove the nuts without compromising the integrity of the stove.
Before I start into this rather larger project, I'm reaching out to you to see if there is any other solution you can think of.
Much appreciated,
Tony
Much appreciated,
Tony
