My saw bogged down and quit today. It would rev up but the chain wouldn't spin. I shut it down and tried to spin it by hand, no luck. I took the saw apart and noticed the bar tip sprocket didn't spin. I cleaned the bar groove, the grease ports, and greased the sprocket. Now it turns but only if I put the bar on edge and press down on the sprocket tooth with a flathead screwdriver. I spun it like that for several revolutions in order to get the grease spread around. But it still only turns with a lot of effort. I can't, for example, spin it using nothing but my thumbnail.
How easy should it turn? The motor is way stronger than my thumbnail so I think it will spin under power. But would that be making the saw work way harder than it has to? Would that damage the saw? Or will the fast rpms heat up the grease and work out whatever gunk is in there once it is running?
Basically, is there any way to diagnose and fix a sprocket or am I looking at buying a new bar?
