I have a gutter with a seam in it. Of course it always leaks from the seam, sometimes a lot. its been doing this for years, I am not going to replace the gutter, so would like to patch it.  The inside has some stuff on the inside around the seam... maybe a glue or caulk... not sure. Point being its not clean at the immediate area.  so I cant caulk it without cleaning out the stuff. The stuff is on there good and the gutter is pretty high up. Yesterday I saw an ad for flex seal  (broken link removed)
It seems like the perfect solution.... any experience with it? Or better yet, anything else you might recommenced thats cheaper and available at homedepot (not mail order)... The idea of a spray compound that can go over a non-perfectly-clean surface is what I am looking for (a gutter seam so there is no pressure either)
maybe some sort of liquid gasket?
Thoughts?
Thanks,
Rick
Thoughts?
Thanks,
Rick
