Ok guys I have a problem and some questions I think you may be able to offer some good advice.
I enjoy splitting my firewood so I was buying it (5-6 years ago) cut but unsplit, in the round. By the time I was done splitting 1/3 to 1/2 of these 4 cord I knew I had a problem. Same thing the following year. I hated to do this but I gave up splitting it and started to get it split. I would like to return to splitting tho, God knows why as I have no time without adding that chore. I do love handling the wood and may have a lot more available time this coming year.
So here's my problem - tingling and numbness in both left and right hands and sometimes lower fore arms. I'd even wake up at night both hands (and forearms sometimes) tingling. It feels like carpal tunnel. I had 1 surgery on right hand in '98 or '99 unrelated to splitting wood and I don't wish to recreate or create an other problem!
So here's my method for splitting and I think this is the problem - my wood is 16" long and rounds vary from 8" to 18" across. The wood is a mixture of hardwoods - oak probably red or black not white, sugar maple, hickory, cherry, yellow birch, sometimes ash, no locust, no elm. I use a chopping block, about 24" across, it's white oak in my yard sitting on the lawn. I use a splitting axe (wedge shaped but not triangular like a maul) probably a 6-7 pound head, not a maul, not a chopping axe. I sometimes get a piece to spilt on 1 hit but 75%+ of the time I have to hit the splitting axe with an 8 pound sledge hammer as the axe is only 1/3 or 1/2 way thru the wood. Sometimes I hit is 3 or 4 times. So I figured why bother trying to split the wood, I can tell a piece by sight that'll split on 1 hit. So I changed my method. I'd set the splitting axe into the round with 1 good hit. Then I'd hold the hickory handle in my left hand while I pound the back of the axe head with the sledge hammer using my right arm choking up 1/2 way on the sledge handle for control. The vibrations from hitting the axe transported thru the handle into my left hand and arm. I think this is the problem. For the right hand and arm, squeezing/holding the wooden handle and the vibration from hitting the axe head is the cause of trouble in that hand.
I never had wedges tho I just got 3 from a friend last weekend. I don't want to buy/make/use a hydraulic splitter. I wonder if using the wedges with the sledge hammer would eliminate most of the vibrations? Perhaps a maul would be the best way? If the maul will spilt clear thru due to their design and weight 90-95% of the time perhaps that'd help? I realize some hickory, some knotty oak or maple and most all yellow birch will not split with 1 hit. Hickory can be fibrous and yellow birch is really bad! I once spent 20 minutes on 1 piece of yellow birch (twisted with a large bulge in the wood!) because I figured one way or another I could get this piece to split but it was not to be. Yellow birch, especially with knots is brutal, it's not elm, but it is nasty stuff. Oak and maple with knots can be tough too but often they split nicely if you can avoid the knot. Like I said, I have split enough wood that I know when a piece will be a problem. I also know how to read the cracks to take advantage of the natural tendency of a piece to split along natural lines it wants to split.
So would wedges be better or would a maul of 8 or 10 pounds split almost anything in 1 hit? I'm 5' 7" 180 pounds and 56. I work in an office (not in top shape) so I know to take my time initially, say working just 1 hour then 2 so I build myself up to doing this. Problem is I'll split for 8 hours straight no breaks once I'm up to speed. The following day I ain't good for much then! Add the tingling and numbness and whatever harm that is causing and I just got concerned enough to stop. Next year I may have a lot of extra time to pace myself over a few weeks vs the 'I must split 4 cord in 5 days' pace I used to do once I'd built myself up to working full time.
Thoughts?
Tom
Thoughts?
Tom
		 Had carpal release surgery on the left hand/wrist in 1992, but it didn't really help.  Actually I was moving an enormous picnic table some years after the surgery, felt a weird feeling in that wrist and could tell the surgery had been for naught.  I am fairly strong for a female, have worked out on weight machines on and off for 8 years now, but I have to limit the length of my wood related exertions.  I am bigger than you, 5'10" but I won't say my weight!  Was hauling too much firewood last week (we got 3 1/2 cords free total) and now my hands are really shot.  I won't be able to split wood for probably a couple weeks now.
