Good question, Charles2. I have four wedges- the Wood Grenade, an old sharp traditional one, one that looks like a big railroad spike, and a new one with an short angle that I cannot set into the top of the logs. I have beat the piss out of the first three (put a mighty bend in the Wood Grenade in a tough crotch). I want to sharpen that new one that has a worthless steep angle. This same question applies to mauls.How sharp should the tip be? Should the tip be ground to the same angle as the body of the wedge? How does anybody know for sure what the ideal angles are?
So it will stick into the round before I start swinging the sledge at it!Pray tell why you want a sharp splitting wedge ?
I have 3 types of wedges 1 -Fairley short with steep angles made of steel for splitting fire wood
2 - nylon felling wedges used for what the name implies
3 - Home made by my Grandfather fence rail splitting wedges very long and heavy
With a handle to beet on.
None of them are sharp or need to be
I got two "grenades" from Northern Tool:seeing as your title refers to splitting wedges:
Currently I have three that look like this :View attachment 172012 with rather blunt tips. That's how they were when they were new. They do 'bounce out' sometimes when started.
I had one with a curved tip that was quite sharp and was easier to get started but it also could cut it's way in and get stuck. Left it somewhere, I really don't miss it.
Heavy hammer is right! I'm not man enough to swing a 20 pound sledge (mine is 8, and my accuracy is still not 100%), and my joints don't even like the 8 pounder.Just get a nice edge that will stick in the wood then swing away. Never have sharpened a wedge or maul if it bounces out hit it harder, if it keeps bouncing out get a bigger hammer. I have a 20 lb sledge it will put just about any wedge into a piece of wood.
Not sure that this holds true. Sharp, cuts. Blunt, splits. For the same reason that most hydro splitters don't use razor sharp wedges...let the wood do the walking. A sharp wedge might get you into a bind that a blunt one following the grain might not.Surely a sharp wedge is easier to drive than a blunt one?
The problem isn't with the cutting edge itself, but rather with their overly abrupt wide taper right behind the edge.
Think of wood grain that has a wave to it (even mild). A blunt wedge will have a tendency to follow the grain. A sharp wedge can have a tendency to cut in and try to shear in a straight line. Very much like the difference between an axe and a maul.What sort of bind?
Hydros don't need sharp edges because they don't get tired!
I would venture a guess as to "yes".I was just splitting some wavy wood yesterday, which prompted me to ask the question. Are you saying the task would have been even more difficult if my tip were sharper? Currently it is blunted, about 1/32 inch thick.
just get a blunt piece of steel & try beating it thru a piece of wood ! If axes where not sharp we prolly wound'nt be here I'm just glad tires are round. Think I'll go out & torch the sharp wedge of my splitter & see how that works. Have you ever skinned a deer with a dull knife blade, not fun. there ya have it.
