Hey All,
A few years back I purchased a Northstar 31ton splitter from Northern. The one with the infamous hose problem. (the hose keeps breaking at the fitting) Well the hose sprung a leak for the umpteenth time the other day and I finally decided enough was enough. I drained the oil and replaced the hose.
While I had the oil drained I decided to go ahead and change the filter. I couldn't find the replacement at Northern so I went to my local hydraulics dealer instead. I showed him the old filter and he gave me one he said was a replacement for it. I went home, put everything together, filled with oil and started splitting.
About an hour later my wife started screaming, "IT'S GUSHING, IT'S GUSHING
" Sure enough I look where the oil filter used to be and hydraulic oil is gushing out. I quickly shut down the engine, grabbed a couple of buckets and kept what oil I could from draining on to the grass. When the oil stopped I looked and the center piece of the flange the oil filter was screwed to exploded and the oil filter was on the ground with the center piece still attached.
Needless to say I now have to buy the flange ($45) and 5 gal of hydraulic oil ($40) on top of what I already paid for the hose ($19) and the new filter ($14). All to fix a hose leak.
My question is this, What caused the flange to fail? The new flange comes with an oil filter that is the same size as the original so if it was the filter, the new one should work. I'm also thinking about putting a ball valve inline with the filter so if this happens again I have a quick shutoff. Any thoughts?
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
