I tried out a Speeco electric splitter from TSC this weekend but it's not splitting everything I need it to so am taking it back and am looking for advice on a gas splitter.......I've done some searches and read a lot of posts but am suffering from info overload. I think I understand the good and bad from reading all the long running arguments on verticle vs. horizontal. Right now I'm looking at the following:
Troy-bilt 27 ton from Lowes ($1299)
MTD 25 ton from Home Depot ($1297)
Huskee 22 ton from TSC ($999)
Powerhorse 20 ton from Northern tool ($999)
The Troy-bilt and MTD seem to be pretty much the same thing, both will do horizontal or verticle, but the Troy has a honda engine (aren't those suspossed to last forever?). The Huskee is about $300 cheaper and seems as capable as the MTD and Troy. The Powerhorse has two different configuratons, both priced about the same, one goes horizontal and verticle, and one is only horizontal but splits on both strokes and both have log cradles. But the closest Northern Tool is an hour away and their splitters have to be assembled.
Will 20 tons handle anything Im likely to encounter, I have a lot of Sweetgum on my property? So is the Honda engine worth the extra cost? How about the Briggs? I believe I remember reading that not all Briggs engines are equal as far as quality goes. Anyone have any expirence with Northern Tool in general and the Powerhorse specifically? I'm leaning toward the Huskee since the TSC is 3 minutes from my house and I haven't seen any bad reports.
Another questions is should I look at used? I've had good luck with CL and buying tools from Home Depot rentals section (got a 6401 from there earlier this year).
