Since I use the splitter during the winter I was thinking of changing the oil over to 5w-30, or is it to early?
zap
zap
spacecowboyIV said:Put full synthetic 5w 30 in and you won't have to worry about the time of year. For the small amount of oil required the cost difference is not that great.
FireAnt said:Zap,
I have been thinking the same thing. I was just searching "Splitter Maintenance" and found nothing. How many times does everybody grease the splitter piston? It says to do it before each use on the sticker. I have not done that...
What is your routine for maintenance? You split all the time.
Thanks
spacecowboyIV said:Zap and Fire, once you get your splitters all tuned up come on over. First one here gets to split all of this for me.....show up early and you can cut it up too!
https://lh6.googleusercontent.com/-YLRMJnT2nP8/TnfI4lxA1PI/AAAAAAAAAFI/qrk2D5pbjvo/s800/IMG_0858.JPG
zapny said:Since I use the splitter during the winter I was thinking of changing the oil over to 5w-30, or is it to early?
zap
freeburn said:How often is it really necessary to change Hydraulic oil? I just changed over to ATF Dex II/III that way I know what I put in when it's time to change it again. Heard that it works a little better in colder weather too. Anyone substantiate that claim or is it bogus?
freeburn said:No filter on my splitter. It says it's internal, which I assume means that it's pretty much non existent, maybe just a screen of some sort.
