Splitter Issue
walhondingnashua
626
ohio
While running my splitter this weekend, I noticed that the fill plug on the tank had a lot of hydraulic oil shooting out of the breather hole. It only happens when the ram is fully retracted (when it hits the end and auto stops). I took the plug off and ran it like that. When the ram hit the end, oil would shoot out but then be fine. This isn't the first time I've used it and have a few cords run through it.
Either the fluid level is too high or you are introducing air into the system. Check fluid level when warm.
My splitter has a tank that's a rectangular box which has the wheels on either end. A lot of horizontal/vertical splitters are like that. The oil fill/vent is on one end. If the splitter is on uneven ground with the vent side lower, fluid can come out. It does not take much of a tilt to do it.
It really should have a tall narrow tank, but it's cheaper to make this way.
Now that yo say that, it was tilted with the vent side down hill. I don't think I have used it on an angle before like that. I would assume that explains everything then. Thanks for the quick responses.
