Last winter & spring I split my wood for this season to 16" because my stove max is 18". Previously, with 18" splits, I sometimes had problems getting the last split or two in because the other splits reduced my room to manuever. I also scrounged up some logs that were already cut to 14" so I've been mostly burning splits with an inch or two of space on each side of them. I found they tend to ignite on the ends as my primary air comes down from above, across the glass, and feed combustion on the sides. Once this is established it often stays like that and takes a good while for the tops of the splits to ignite. This lets the stove temp drop off some.
This season I have tried to cut my splits closer to 17 and 18" wide to get maximum fuel in the firebox. I'm wondering if others with top-centric air have this problem.
